I have an 18 RZX2 with led rings on the tower speakers and blade lighting. I was cleaning the boat and noticed that on the back of one of the in boat speakers there was rgb wires that weren’t hook up to anything. I went on wetsounds website and saw that the revo 8’s have built in less. Is it just a matter of hooking these up to the controller to work? Strange that Tige wouldn’t hook these up from the factory.
RGB light on in boat speakers
In the past, I have found that the speakers do not have the 4-way female boat side harness connected. These can be sourced through Wet Sounds. One per speaker.
Whatever wire your source, you want stranded, not solid conductor.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostIn the past, I have found that the speakers do not have the 4-way female boat side harness connected. These can be sourced through Wet Sounds. One per speaker.
If you find the controller, you will see thats its a 2 chnl controller and has 2 plugs for outputs. id wire the 4 main cabin to one chnl and the bow and tower to the 2nd chnl.
https://www.wetsounds.com/product/RF-RFB-MC-V2Last edited by chpthril; 07-28-2020, 11:05 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
