Okay... this one is a bit strange. We have a 2018 Tige Z1 with Tige Clear touch screen and wet sounds amps (2 of them) and two Rev 8's on the tower. Everything works great until we have been running for about an hour - then static starts to creep in and an audible buzz comes from all the speakers on the system including the boat speakers and the tower speakers. This is only after an hour or so on the water with everything working great up till that time. The only thing I can think of is the Amps are getting hot but when I felt them they do not feel warm. Any ideas? Anyone?
Wetsounds Static
Check with a Tige dealer, as there is a service bulletin regarding unwanted noise. Good place to start.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by wired1236 View Post18-R23, same problem but I installed them aftermarketMy issue is just with the bow speakers so thought it may be a bad RCA but haven't dug into yet.
With speakers powered by difference experiencing the same issue, does point upstream to to something like the ICE box or system voltage. However, there was a technical service bulletin for the 2017 amps producing some unwanted noise after getting warmed up.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
