Well, it's finally done
And I know Throg is happy to have his boat back
I want to thank ET for allowing me the opportunity to do the system, Phil and all the folks at Kicker, and the guys at Superior Plastics (my local plastics fab guy) and David at Earmark for allowing me to bounce some thoughts off him about fishing the 09 Illusion X tower. Also thanks to Jason B for sharing his thoughts on the acrylic.
The system consist of:
The brand new KM6500.2 tower speaker system + an additional pair of the KM6500 mids all powered the all new ZXM450.2 marine amp. This called "the 6-pack"
In the boat we have:
One pair of KM6250.2 marine component set custom mounted in the walk-way and 3 pair of the KM6200 coax mounted in the factory locations.
Two Kicker KM10 marine subs in custom enclosure located under the helm and two more SKM-10 marine subs w/enclosures under each of the corner seats.
Two new ZXM700.5 Marine amps power everything in the cabin for a total of 840 watts rms of pounding subs and 560 watts RMS driving the 8 in-boats.
Kicker KQ9 EQ to control the sub level and fade from tower to cabin.
All Kicker wire/cable, Fuse holders, and Distro-blocks
Custom battery enclosure with Pro-Mariner charger and Blue-Sea ACR mounted on the front and an acrylic window and LEDs
Custom amp rack for the 3 amps, acrylic/LED back-lighting and distrobution blocks. All the in-boats also have LED's in the grills.
Here are a few nighttime shots of the LEDs and then few from this morning.
