What is the model of the stock stereo in the 22IR Tige? And what is the easiest way to connect your IPOD?
2004 22IR Stereo Question
Probably a Clarion, and could be either an XMD1 or XMD3. Need to check, but I dont think either has a set of AUX RCAs in the rear. So, either a head-unit change or an FM modulator type Ipod hookup.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by rushin View Postyes, the XMD3 does have the AUX RCA's in the rear. I had that in my '04 and that is how I did it with the IPOD.
If so, you can go with an inexpensive 3.3mm headphone to RCA cable or a remote mounted jack that uses a double-ended 3.5mm cable. I also have on order an Ipod specific cable that uses the data link on the bottom of the ipod and then has RCA's and a power and ground source for charging. They are currently not shipping, but should be soon.
here is a pic of what the remote jack will look like, less the USB socket. This can be mounted in the glovebox, or at the drivers side or transom with extension cables. You can install more then one with splitters, but only use one at a time.
http://www.tigeowners.com/forum/show...74&postcount=2Last edited by chpthril; 04-08-2010, 06:50 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
chpthril-->I also have on order an Ipod specific cable that uses the data link on the bottom of the ipod and then has RCA's and a power and ground source for charging. They are currently not shipping, but should be soon.I'm on a boat man. I got my flippy floppies....
Originally posted by rushin View Postchpthril-->
When do you expect these? I have been looking for one!!Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
