The volume does not go up gradually on my head unit like its supposed to, meaning every time I hit the volume button to turn it up it should get a little louder with every click but it don't. It stays the same relatively quite until 12 on the volume then it gets louder and stays the same until you get to 22 on the volume and it gets really loud all of a sudden. Its kind of like getting in a car only to find out that someone turned the radio volume all the way up before they shut it off, if you know what I mean.Is there any way to correct this or is it just a bad head unit?
volume goes up in spikes on my clarion
oleblue,
This could be within the source unit. If you have a removeable faceplate try cleaning up the contacts first with a pencil eraser or with tuner wash and a very soft toothbrush. If that fix takes then coat the contacts with dielectric grease to provide a barrier against corrosion.
You may have experienced some water damage. If your Clarion has a rotary volume control, then take the top off the chassis and rinse the pot with tuner wash.
If you have hardwired remote controls then disconnect that cable from the back of the chassis to see if the problem corrects itself.
David
Earmark Marinewww.earmarkmarine.com
This is the source unit that I have.
http://www.hookedontronics.com/show_....jsp?cid=13975
It doesn't have detachable face or a rotary volume button. I haven't tried to disconnect the plug from the back of the unit. I will give that a shot today and see what happens.
Originally posted by oleblue View PostThe volume does not go up gradually on my head unit like its supposed to, meaning every time I hit the volume button to turn it up it should get a little louder with every click but it don't. It stays the same relatively quite until 12 on the volume then it gets louder and stays the same until you get to 22 on the volume and it gets really loud all of a sudden. Its kind of like getting in a car only to find out that someone turned the radio volume all the way up before they shut it off, if you know what I mean.Is there any way to correct this or is it just a bad head unit?
I have a used one for sale.
Originally posted by oleblue View PostI can't even find a clarion xmd3 to replace it with. Anybody know of another source unit that I can use the same plug with without having to rewire everything.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by oleblue View PostNobody, mine is a XMD3. So I can use the same plug that I have now with the units you listed Chpthril.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
