^^^X2^^^
Wiring diagrams for system?
Originally posted by chpthril View PostYes, that's my un-encrypted emailShoot me an email, and i'll reply back with an estimate. Depending on the length of power cable, you're looking at between $125-$160 for all the install supplies.
Originally posted by h2osk8er00 View PostSweet... can't wait... Tower Speakers came in today! **** yeah!!! Im stoked and can't wait to start the project... I'll try and get the e-mail out be Tuesday at the latest...weather pending... More snow heading out here! I hate the winter!! Thx MikeHay, where are you in relation to Salisbury? it's just south of the DE state line mid way between the bay an d the Atlantic. The home office of the other company I work for is based there.
Originally posted by jrj701 View PostH2O, I was reading your post with all the questions and saw you were talking about building a sub box and worried about getting it thru the small door to the storage area. I am just wrapping up my install with much help from members on here especially Chpthril. He suggested putting 2 10" subs on the bulkhead wall under the drivers dash. After talking to Phil from Kicker he said I would need 2 cf of box although going up to 3 cf would be even better. Well after looking at the door I would have to squeeze it thru, it became obvious that I would have to do a lot of work with cardboard templates to figure out the shape and size. After some trial and error I came up with what I wanted to use and cut all the wood (3/4 Birch plywood). I then pre drilled all the screw holes and completely dry assembled it to make sure it fit together right.. I then tore it down and figured out how much of it could be assembled prior to squeezing it in the hole. I glued and screwed that portion and put it in the hole. After that, and here comes the hard part, I finished the assembly in the compartment. I built a 5 sided box and used the boats bulkhead wall as the sixth side. Once the 2 10” cutouts were made in the bulkhead I was able to reach inside the box to finish screwing it together and seal all the seams. I originally painted all the box parts with truck bed paint, but will probably go ahead and add carpet to all the exterior areas I can. It was a major pain, but I ended up with 2.75 cf in the end. I will try and get some pictures posted of the finished product asap.
Originally posted by chpthril View PostHay, where are you in relation to Salisbury? it's just south of the DE state line mid way between the bay an d the Atlantic. The home office of the other company I work for is based there.
Originally posted by h2osk8er00 View PostThat is just on the other side of the Chesapeake Bay.. On land it's a 2 hour drive though... I dated a girl that went there a couple years ago... long story short it is not too far... you ever go up there?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Measurments on the way! (No Homo- lol)
Originally posted by chpthril View PostYeah, we do a 3 day conference twice a year. We were looking at next month, but they wont get it together so it will prolly be May.
Mike
Mike
Originally posted by h2osk8er00 View PostI measured the length and it appears that I will need approx. 16 feet to make it from the battery to the amp area... I added and extra foot but if you think I should get more than you're the boss.. I would like to get everything through you so just send me a quote and the best way to take car of business. Thanks!
Mike
mikesliquidaudio(at)bellsouth(dot)netMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
