Originally posted by ajholt7
View Post
Kicker comp vr deal?
That boat was ordered with no stereo, so it got a keel-up install. The time saved by removing the seat back, allowing access to the storage, was well worth the few minutes it took to find the screws/nuts holding it on. The drivers side was a lot harder because you have to reach through the little storage door, but there was a ballast tank in the way, making it really difficult.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by ajholt7 View PostThis may be stupid but, can I build a box from lexan?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by ajholt7 View PostI have access to lexan scraps. I work with it all the time. Question: 1/2" or 1/4"?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by ajholt7 View PostBought a used 700.5 for $175. Can't wait to get this hooked up. Gotta start rounding up cable, crimp connectors, distribution blocks, circuit breaker, and what am I forgetting. Worst part is my battery switch is on the oposite side of the boat. = long power cable run $$.
Dont connect to the battery switch, you need to go directly to the battery. Does you 20V have the EIDB dual battery setup? If so, the "House" battery is the one under the seat behind the driver. It takes about 20ft, if I remember from the last one, to reach from that battery to the amp.
www.waytekwire.com will have the marine rated manual-reset circuit breaker that I like to use. The also have battery eyelets. I like to solder them on V's crimping. Part # 36462 is a tinned brass w/ 5/16" eyelet. You'll need at least a 90A breaker (part # 46782)and 4 ga wire if you are just going to power the zx700.5. If you're going to power more amps, then those will need to be taken into account for your choice of breaker rating and wire size.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by ajholt7 View PostWhat gauge wire and breaker for say 1200 watts max. I don't think I would ever go over that.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
