Other than waiting until you find out the hard way that you can't keep your battery/batteries charged, how do you know when you need to upgrade to a bigger alternator or add another battery?
I am thinking of adding another amp but don't want to overload my alternator. It is still a stock alternator, 60-65 amps.
There is a formula Amp = Watts/Volts. So, running through my equipment below:
I currently have 1 starting battery and 1 stereo battery (Trojan Deep Cycle) that are connected with a Yandina combiner.
I am currently running (with no problems):
2 Cadence SQA-4 amps in a 4 x 60 watt mode (240 watts each.) 1 is running 4 Polk Audio db651's in-boats, the other is runing 4 Polk Audios db651 tower speakers
1 Cadence SQA-1 amp in a 1 x 500 watt (maybe 700 watt?) Runnig a XS12 Wetsound sub
I am going to upgrade my tower speakers to HLCD speakers. I am adding a Boston Acoustic GT28 amp in a 2 x 350 watt (2ohm mode).
So I will be adding another 700 watts but removing 240 watts (removing the current tower Cadence SQA-4 amp).
BUT, I am considering using the SQA-4 amp and rewiring both the SQA-4 amps in a bridged mode to power the in-boats. This would be a 2 x 200 watt mode (per Cadence spec). With the 4 in-boats, that increases the wattage from 240 to 400 for the in-boats.
Plus the increase on the tower speakers (700 - 240) that is a total increase of 620 watts.
So, my new total watts (assuming the sub is at 700) would be 1800.
Back to the formula: 1800 watts / 12 volts = 150 amps.
If this is all correct, I am OK with one stero battery and a 65 amp alternator?
Thanks
Thanks
