I don't know if this is normal or not: Whenever I hit a hard wave, the stereo head resets itself. It is as if it loses power to the head unit. Is this normal, if not any ideas? All the connections are tight.
Stereo cuts out on large waves
With the stereo on, start wiggling wires and gently tugging on wires in hopes of duplicating the problem. Pay close attention to black ground wire, the red remote turn-on, and the yellow memory wire as well as the main plug in the back H/U.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Moki View PostI don't know if this is normal or not: Whenever I hit a hard wave, the stereo head resets itself. It is as if it loses power to the head unit. Is this normal, if not any ideas? All the connections are tight.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert View PostIf chpthril's suggestion doesn't bring you joy, it could be that your H/U has got a loose connection inside of it.
Originally posted by evil0ne View PostHow about a loose wire on one of the batteries? Is it only the stereo or anything else electric doing weird things?
Originally posted by dingleberry View PostAre these the same large waves that you showed in your "Powell Glassification" thread?
Originally posted by da.bell View PostHow old is the HU? Could the HU be old enough that the wires inside the HU are lose?
Thanks for everybody's input. I hope that I find joy.
