There's a panel in there I need to unbolt, but I'm guessing there are coils behind it.
FREEZER HELP!
I'd call a repair guy and have him give you an estimate. A new fridge is not cheap...the wife just dropped $2500 on one of those LG fridges with the french doors (freezer on the bottom).Originally posted by NICKYPOO View PostMy freezer crapped out last night. Fridge side is working fine. Freezer side, no bueno. Anyone?
Trying to find parts for these things is impossible with all the branding and rebranding going on.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Neither side gets cols, fans blow, compressor is hot....then this is your problem.
I bet if you pull it off and open it, it is burned to a crisp. They are designed to do so.
You can but a universal way cheaper than a model specific (which is what the repair man will likely try to do) like this.
It plugs onto the prongs, you wire up three wire nuts, and you are done. They are about $15 and take 5 minutes to install. Most of them a re the protection circuit and the relay all in one.
What happened on your fridge is the protection circuit melted, so the relay is still working, but the compressor is on, but no circulating freon. Fans are also turning. Things that cause this are age, and bad compressors, and faulty design. Chances are yours just got old.Last edited by spharis; 04-19-2007, 03:50 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
Supreme Tigé Master- Sep 2005
- 9278
- 2005 24v
WoW....... you guys know your fridge'sPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
- 9278
- 2005 24v
Good thing I was starting to get worried.......Originally posted by dogbert View PostYeah, if everything goes to hell, we can all stick together and come out ok..
- 9278
- 2005 24v
BTW sorry for jacking
Back to the topicPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
