My buddy and boat ownership partner is having a hard time finding someone besides the dealer to install the 5 pin trailer connector on his 2008 Touraeg. He called the dealer and they want $1500 for a hitch and trailer connector install! The local trailer hitch company will not touch the trailer light install because of some issues with the Touraeg computer. Anyone have any insight into this install or suggestions for a place to do the install in Austin at a non ridiculous price?
Toureag trailer hitch and trailer light install
GuestTags: None
here is the wiring kit for 65 bucks. It's plug and play
http://www.etrailer.com/t1-2008_Volkswagen_Touareg.htmOriginally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
here is the receiver with no drilling required. I'd just do it all myself, but that's just me.
http://www.etrailer.com/hitch-2008_V...en_Touareg.htmOriginally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Guest
Wow, I knew dealers were overpriced but 1500 is nuts for under 300 in parts. I am pretty sure this would be from scratch but I have to look closer at his truck. Thanks for the links. I still wonder why the trailer shop would not touch the wiring harness install.
Austin,
I have never done your exact car, but I have done probably a dozen trucks, jeeps, and cars, 1 completely from scratch, but all the others all you do is unplug a light and then plug the harness in and then ground it. It's so easy. and I can't imagine it messing up the computer... it's just some wires.
and the reciever it lookks like it's just bolts, so I really think you can do this on your own if you have the basic tools.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Guest
Just noticed that the etrailer harness is a 4 pole and we need a 5 pole, for the surge brakes I guess. Or is there a way for the 4 pole to work that I am missing?
Originally posted by AustinSouthSide View PostJust noticed that the etrailer harness is a 4 pole and we need a 5 pole, for the surge brakes I guess. Or is there a way for the 4 pole to work that I am missing?
Guest
I have been reading on a Touraeg forum that we need to get a amp module for the brakes because wiring off the backup lights like we all normally do will cause the computer to get upset and send a bunch of warnings and complain a lot. I also read that there is not enough power to cause the brakes to disengage. Going to try to figure out what the amp module costs and how to install. Stupid expensive foreign cars. :-)
does your trailer have to have the brake unlock? i mean IMO it's a lot easier to just put the key in....
I'd look into that first. If your trailer doesn't have the electrical lock out no point in resereaching it. (sorry if I missed somewhere where you said it did.)Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
Originally posted by AustinSouthSide View PostI have been reading on a Touraeg forum that we need to get a amp module for the brakes because wiring off the backup lights like we all normally do will cause the computer to get upset and send a bunch of warnings and complain a lot. I also read that there is not enough power to cause the brakes to disengage. Going to try to figure out what the amp module costs and how to install. Stupid expensive foreign cars. :-)
If there isn't a enough power just run a relay from your battery to the trailer switch and then do lights. I can't imagine the computer doing anything like that with a relay, the current draw would be so low....
maybe chpthril will chime in here. but like I said before make sure your trailer has the electric overide, if it doesn't you don't need the 5 pin.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
