Prop guard height 21XZ
    Does anyone know how high off the ground the prop guard sits on a 21ZX with the standard 15" or upgraded 18" wheels? Trying to compare to the prop guard height on an R21.
    Thanks!
    Just a guess, but with the same tires I’d guess they would be very similar.
      My 23zx is same height as the rzx2 with same wheels. Both were quite a bit higher than my original Z1
      I used to scrape my driveway hard on the Z1 with normal tires - but no issue at all with the upgraded wheels on the 23zx.
      I did have to remove the lower portion of the step at the front of the trailer
          Which wheel size did you stick with?
