Just got a newer Z1 with electronic disc brakes. I came from an '08 with surge brakes. I bought an expensive RF brake controller but I was told that I don't need one as these newer boatmate trailers have a surge/electronic brake combo. Was told the brake controller will not even do anything and will not engage the brakes or increase the sensitivity. Is this the case?
Bought brake controller but not needed with electronic disc brakes???
Originally posted by Frosty_Power View PostJust got a newer Z1 with electronic disc brakes. I came from an '08 with surge brakes. I bought an expensive RF brake controller but I was told that I don't need one as these newer boatmate trailers have a surge/electronic brake combo. Was told the brake controller will not even do anything and will not engage the brakes or increase the sensitivity. Is this the case?
Tigé Junkie
- May 2013
- 920
- Central MN
What you have is an electronic bypass. With surge brakes, if there is pressure on the slide tongue then it applies the brakes, the more pressure the more the brakes are applied with the hydraulic pressure. When backing up, you are applying pressure to the tongue, so it would apply the brakes. The back up lights is what sends power through the 5 wire connection to a solenoid valve that allows the fluid to bypass and not apply pressure. I don't have a picture currently, but if you only have a 4 pin available, you can turn the plug sideways and connect the brake bypass to your running light pin (turn your headlights/running lights on) and because it is now powered your brakes would bypass when backing. Remember to hook it up correctly after.
Some people are opting for electric over hydraulic brakes with the larger boats. In this case you would use your brake controller, it sends a signal to a separate hydraulic unit that adjusts the brakes similar to a trailer with actual electronic brakes."I think I am pretty smart for an idiot"
This is what I will be adding to my trailer soon. It allows similar response as electric brakes while keeping the brakes hydraulic and not trying to submerge electro-magnetic brakes.
https://www.etrailer.com/Trailer-Bra...FQsIaQod7wUAlw
