Well, barely two years have passed and I had to replace my latest set of trailer tires. Only made a few trips to Havasu on them. Granted, the last set was a cheap no-name brand of radials because that is what the store had when I needed them. This time as I was pulling in to our destination I could see the front left tire starting to wobble/bulge. Historically, I've found this to mean it will totally separate soon.
I have a 2007 Extreme trailer that originally came with an odd off-size low profile tire. Last time I moved up to 205/75-14's. This time after some careful measurements I moved up to 215/75-14's, which are also a standard size and have a little higher load rating. I am trying the Carlisle Radial Trail HD trailer tire, which seems to be fairly new (still made in China though). Anyone have any experience? The main thing I like is that they are truly speed rated up to 81MPH. I never exceed the speed limit when towing, but I have to believe that a tire rated for that speed will live longer at the speeds I drive.
Also found out that torsion axles may be harder on tires than leaf springs, and are very sensitive to trailer level. My Suburban has air leveling so we always tow the trailer level. However, I guess any time the trailer tilts up and down the torsion axles are independent and don't transfer some load back and forth. Therefore in certain cases individual tires need to carry more weight briefly.
One thing I did for some piece of mind this year is buy a handheld laser thermometer off Amazon. Every time we stop during a trip, I can quickly take the temperatures of the wheel hubs and tire treads to make sure nothing is getting out of line.
