Okay, well not to rub anything in but its well into 70-90's here is Southern California and I have the worst itch to get the boat out. SO...I was pulling the boat out everything is fine, I went to back into my driveway like I have hundred of times before and the brakes are locking up hard while in reverse. I called the trailer manufacture (Sport Boat Trailer) and they are telling me its the reverse lock out valve is probably not working. Has anyone had this issue? Here is some more information and troubleshooting I did:
1. Cleaned the terminals on the both the trailer (5 Pin Flat) and truck (9 Pin Round) to ensure proper grounding and power to the reverse valve.
2. Double checked the break away cable, and mechanism is not tripped.
3. Moving forward breaks work fine, and the brakes are not on while moving forward.
4. Its a UFP Model 60-A inner slide looks clean no rust.
If I purchase the reverse the valve, any idea of how difficult the swap will be? Is it guaranteed this is my problem? Is it smarter to just replace the entire inner slide and reverse lock out valve and do a full swap? Any help is appreciated!
UFP A-60 Inner slide-$181.00
Reverse Lockout-$55.00
Total for both.. call in $240.00
Thanks again, don't want to be stuck on the launch ramp.
