The forward pull is what is desired, but the bow should rest on the rubber and the bow eye should nudge up to the bow stop. That way when the traler is strapped and pulled tight it has front support on the bow stop and bow roller. A Second strap or cable is only a backup, it goes from the trailer frame to the bow eye and secures Loosely in the case that the actual winch strap breaks the boat is still somewhat secured to the trailer.
Boat mate trailer???
I am thinking that a racket strap around the trailer frame with a downward pull on the bow eye is going to be the trick. I took it to the dealer today and it sits perfect in there pond but then when you pull forward it lifts a little bit? That or have another wheel made to mount lower under the factory wheel in the trailer to create some down force. Option one sounds like an easier fix and (SHOULD) work right?
Does this trailer have the spacers on the bunks to raise it up so the prop doesn't hit the trailer? If so I can see how the bump stop is now in the wrong spot. I agree with the lwndr, call Boatmate or have your dealer call Boatmate and get it cleared up, I'm pretty sure it's not supposed to do that.2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Tigé Junkie
- May 2013
- 920
- Central MN
Originally posted by Ewok View PostDoes this trailer have the spacers on the bunks to raise it up so the prop doesn't hit the trailer? If so I can see how the bump stop is now in the wrong spot. I agree with the lwndr, call Boatmate or have your dealer call Boatmate and get it cleared up, I'm pretty sure it's not supposed to do that."I think I am pretty smart for an idiot"
I've called both boat mate and taken it to the dealer here in Utah that sells tiges and boat mate said he is checking with his engineers and the dealer said it will hurt nothing? Personally I don't like the idea of it moving at all up and down on the bow. Every other boat I have had has set right in the bump stop? I guess I will see what boat mate says this following week??? Thanks for any and all help...
Originally posted by WACKY!!! View PostI've called both boat mate and taken it to the dealer here in Utah that sells tiges and boat mate said he is checking with his engineers and the dealer said it will hurt nothing? Personally I don't like the idea of it moving at all up and down on the bow. Every other boat I have had has set right in the bump stop? I guess I will see what boat mate says this following week??? Thanks for any and all help...
Sent from my SAMSUNG-SM-G925A using Tapatalk2015 Tigé R20
Originally posted by Dandy View PostI believe the trailer and shim issue was only for the 2013 Z1 Boatmate Trailers.
And for guys with the trailers with the spacers, have you had similar issues with the bow stop being too low?2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
