Hi there first post here but I have a 2015 tige R20 that I recently bought new. I have a question on trailer hookup to the winch. It seems to me that when I hook up the winch under the rubber slider and reel is tight that the boat does not not sit on the rubber wheels. Anyone else have this issue???
Boat mate trailer???
Our 2014 R20 with a boat mate trailer goes under the bow stop. Is your boat launch steep? If it is your boat will be floating high in the backend and touching the rubber roller, but when you pull out of the lake the boat goes down pulling away from the roller, causing the boat to be not touching. Try pulling ahead a few feet after loading boat and see if you can winch it up some more.
Can you post some pictures so we can see
Tigé Junkie
- May 2013
- 920
- Central MN
Can you adjust the height of the stop/winch mount? Our trailer had the front stop sleeved so that we can raise or lower the height of where the bow stop is. It looks like yours should be higher so that the eye does not hit it and allows the boat to rest on it."I think I am pretty smart for an idiot"
