The sticker on my Boatmate says re-torque to 110 ft.lbs. at 100 and 500 miles whenever a wheel is installed. Still hate it for you...good luck with the repairs.
tires and wheels fell off of my trailer
Few years ago both my friend and myself though someone loosened the lug nuts on our trailer tires at the lake. I was following him and saw his wheel wobbling. We pulled over and tightened the lug nuts. I had already shered off one of the bolts. We both need to buy new rims and new bolrs . I check everytime now going to and returning from the lakeLet it be!!!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by Duncan View PostGuess I need to buy a torque wrench. Any suggestions on type/brand?
Here's a typical photo:
This 1/2 inch drive unit is $25 from Sears. It will last the rest of your life.
Like I said before, I had never checked my lugs (on anything) other than right after I changed a tire.
I am heading out to Lake Mojave later today, so last night I went through my normal routine and pre-trip check list, and added checking my lugs. 3 of the 4 wheels were locked solid, but all 5 lugs on one wheel were a little loose. I was able to put maybe a quarter turn on each one. Don't know if they were loose enough to come off during the trip, but I sure am glad I checked.
Originally posted by wired1236 View PostFunny - or not so.
So how many people checked their lugs after this post?
I did since I put new wheels on this winter and I was able to put 1/4 turn more too to get it up to 90ft lbs.
Tigé Expert
- Sep 2007
- 2409
- Manitoba Canada
- '06 Wakesetter VLX, Prev '06 Tige 24V - '03 Tige22i - '99 Sunsetter - '99 Tige 21i, -'96 Ski Chall
Oh man sorry to hear that. I hope the dealer and trailer manufacturer will have some good will and help with the cost.
If it was a broken stud, I would tell them that the trailer manufacturer made a mistake and torqued the nuts too tight and once one stud broke it was a chain reaction. I'm not sure down in the States but there a law here about "merchantable quality" and the ultimate responsibility of the vendor.Life is good...
Happy Wife Happy Life
My Boatmate trailer had only about 300 miles on it when I started hearing a funny noise coming from the trailer. I got it home and found that one of the wheels was about to fall off the axle. They were so loose I could turn the lugnuts with my fingers! It was a close call and now I check them regularly.
Originally posted by WABoating View PostI have had very bad (as in "damaged the equipment I was working on") experiences with the click-type and electronic torque wrenches. I now have a selection of torsion bar torque wrenches. You apply torque, the separate metal bar bends to show the force you're applying, done. There are no moving parts, nothing to be (mis)adjusted, nothing to ever go wrong. That's my $0.02.
I know this is an old post, and I have been out of the aftermarket wheel and custom truck scene for a years, but whenever we sold and/or installed aftermarket wheels, one thing we always checked was that the taper on the lugnut matched the taper on the wheels. Back 10-15 years ago there was different taper for different wheels hence steel vs. aluminum. If the taper was wrong and wrong lugnuts, the lugnuts sure will come loose in a hurry. We also had this happened to a customer once, and they were told and you should check lugnuts at about 50 miles and again at 500 miles after wheels have been removed.Friends don't let friends POWERTURN
