My driveway has multiple slopes that cause my prop guard to drag for a couple feet when backing it in. I once saw a trailer with a couple heavy duty castor wheels welded to the prop guard. Does this work? Where do I get the wheels? I have a buddy with a welder so this would be my Intro to Welding 101 course
Prop Guard Wheels
Are you talking about using actual swivel casters or the steel rollers that a lot of tow boat trailers have? I don't think you'd want casters as they would hang too low and always be dragging.
You could make the rollers pretty easily by purchasing a foot of, say, 1" x .25" wall tube. Then cut 4 tabs to weld to the bottom of the prop guard. Drill a 1/2" hole in the tabs. Cut the tube at least in half or shorter if you want. Run a 1/2" bolt through one tab, through the tube, through a washer, through the next tab and then put a nut on tight. Put the whole assembly against the prop guard and weld in place. Remove the bolt and washer. Apply anti-seize heavily to the inside of the tube. Reinstall the bolt, but not the washer. Put the washer on the outside of the tab with the nut. Use a lock nut to tighten it down but not so tight to prevent the roller from turning.
As the above said...you don't want to go below as you'll lose clearance. You'd want to mount to the side like shown below. I have the same issue on one side of my driveway that has a dip and makes my trailer drag. I have the wheels but it still makes a horrible sound dragging so I've made a bit of a wood bridge to raise that side of the trailer. Not ideal but it works.
Originally posted by UNSTUCK View PostAre you talking about using actual swivel casters or the steel rollers that a lot of tow boat trailers have? I don't think you'd want casters as they would hang too low and always be dragging.
Skiguy, I just set up my trailer with casters from castercity.com. I called them for a recommendation and they recommended the RIGID EXTRA HEAVY POLYURETHANE ON ALUMINUM (see link below). They highly recommended rigid over swivel indicating that a sharp blow to a swivel castor at the wrong angle will snap it off. The casters came with mounting plates and a welder friend cut and welded 2" square tubing to the frame. These casters aren't cheap but it works amazingly well. They gave me 20% off the list price when I called in.
https://shop.castercity.com/ProductD...e=G15CP8x2PS-R
