frist time out this year ,and man its very hard to steer left and right. boat is 21v 02 tige, is there some where to lube.
stiff steering
Originally posted by dogbert View PostNope, time to replace the steering cable. It's lasted a long time.
Nah just kidding!He's right, replace the steering cable. The way I see it, if you are going to pull the steering cable out to lube it you might as well just replace it. Then at least it will last longer.
Common Sense is not so Common
Steering cables wear out for various reasons. Usually its not due to use but lack of use. When the cable gets wet. as its certain to do, the water gets inside and corrodes. Most of the time you notice this at the start of the season because the cable has been sitting and hasnt moved and also your not used to the feel of the wheel.
Ofcourse there are other theories about steering cables. One being that the fiction of the water builds up an electric charge on the steering cable and with the addition of water corrodes.Common Sense is not so Common
Originally posted by 3mk View Postthats only 7 years but i only use the boat maybe for 5 weeks a season.my old boat is 23 years old just changed steering cable last year.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by 3mk View Postmaybe the boat building rocket scientist should keep the cable out of the bilage canal thats proabley why the old boat lasted so long
I would rather put up with stiff steering cables and replace it every couple years instead of having some unfortunate accident because my steering failed...Common Sense is not so Common
Originally posted by 3mk View Postmaybe the boat building rocket scientist should keep the cable out of the bilage canal thats proabley why the old boat lasted so longIf its not fun, Why do it?
Originally posted by zad0030 View PostWell with having a rudder it doesnt leave you with much options on were and how to route and implicate a cable. Plus being a tow boat the bilges are extremely shallow with not much space to add a bunch of extra equipment. Theres always the alternative of having "fly by wire" steering, but thats just one more important system that could fail in the marine environment.
3mk, what was your old boat?Mike Allen, Tigé owner since 1997
In this case, lack of use will do more harm then over use......................and I'm still talking about steering cableMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
