BTW, virtually every reference I've seen with respect to the use of Iroko in marine applications (e.g., planking, keels, rudders, swim platforms, etc.) refers to it as African Teak. It's also interesting that it's used in a variety of in the water applications on some pretty darn expensive boats.
So, to me, the jury's still out on whether or not it's ok to use. It does sound like the vendor that supplied Tige with their platforms provided an inferior quality product in some cases. Keep in mind that boat manufacturers don't make many boats, so you don't have the benefit of an large install base to learn from and adapt. They may not always here from the dealers either, which is their primary source of information.
I had a similar situation arise with my Monster Tower. Virtually all of the hardware used to attach the tower pieces together rusted, even though it was stainless. I called them up and they said they'd received a bad batch of stainless hardware from a vendor. I promptly got replacements.
All that said, if LabTrainer's platform is delaminating, then it should be replaced, but I've not heard that this is actually the case. If it doesn't look so good after a weeklong vacation in some mineral rich water, then it probably just needs some TLC to clean it up.
If you do have an Iroko platform, it does sound like you need to make sure you oil for sure or it will have issues. Other types of teak are a little more resilient, but they also need to be oiled and cleaned regularly.
BTW, if you need a good product for this, try that Snappy Nu Teak Cleaner I did a review of. It really does a good job of removing minerals and other crap your teak platform will absorb.
Your mileage may vary.
