It was my day to be the idiot... help
    Should be fairly easy to see if you have one or not. If you do, it is a fairly easy fix. Just be sure and disconnect the battery before you start working. If not, hopefully someone else can help out.
      Originally posted by laserfish View Post
      The main battery + power cable is connected to the fuse, and the fuse is connected to the starter. All within 1 inch. Should be able to see it at the starter if your boat has one, not all do. About a 1/2 inch square cube. Mine is whitish plastic. Ill try to get a pic for you.
      LASERFISH, YOU ARE THE MAN!!!
      By Noon, I had it fixed and had the boat on the water! The part number is 88-79023A91 for future for anyone else.
      Thanks again laserfish!
        Glad I could be of help. You only make that mistake once (I hope I never make it again).
