2002 21v FOX riders edition steering cable?
    Quote:
    Originally Posted by whitlock87
    I changed my cable last month. Let give you some tips based on what happen with me.
    2) Remove the mounting nut (this is the big nut that hold the guide tube to hull. It will take 2 wrenches, as the bolt is designed to spin)
    3) Now pull the cable up into the locker, and remove the guide tube.
    You should not have to do this. Remove the nut from the support tube only and pull the cable out.
    Actually, I had to remove the tube as it spun before the nut came loose. Several others I spoke with had the same issue.
