I noticed a similar problem with our new '07 rz2. It would surge a few mph up and down with speed set engaged. Inquired about a possible remedy, was told the problem could be that I wasn't fully engaging the accelerator while using the speed set. After confirming I was using it correctly the service dept. determined the engine ecu needed to be reflashed. After that was done speed set problems disappeared.
Speedset Variance
Guest
Originally posted by Wet Sand View PostI noticed a similar problem with our new '07 rz2. It would surge a few mph up and down with speed set engaged. Inquired about a possible remedy, was told the problem could be that I wasn't fully engaging the accelerator while using the speed set. After confirming I was using it correctly the service dept. determined the engine ecu needed to be reflashed. After that was done speed set problems disappeared.
Original Poster
I posted the original question about the surging and the seemingly wide variation in speed when the speedset was engaged (throttle WOT). I am having my first service done next week and the shop will check it out. They suspect a faulty paddle wheel, but I will mention "reflashing the ECU". If they look at me funny, I'll report that, too!
My speed set always worker within a .5 mph, but yesterday at the lake it was fluctuating between 3 and 5 mph.
I guess I need to take it in to get it adjusted. What do I tell the service department that they need to do?The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by 1Lab_trainer View PostMy 20V surges with throttle set at WOT. I varies by .3-.5 mph but the surge is irritating.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Have you had your speed variance issue resolved? I am having the same issue with my 2008 20v, very frustrating to ski, the surging is so strong that it messes with balance & timing!! The old "perfect pass" system could be easily adjusted to compensate for this any idea how to make parrameter changes within the "speedset" system? Thanks....Kevin
Their is always some variance with the Speed Set. It normally never goes over when I use it. It is usually with in 1 mph of the Set speed. It will never be dead on as a skier or boarder will create different levels of drag for the boat to deal with. Also water conditions play a huge roll as well.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Originally posted by JeWyDu View PostThe set conditions where exceptional & strength of speed surges where strong enough to through off my balance (forcing me to break at my hips). Speed varience is approx. 4 mph...any idea if you can change speedset parameter?
