what is better about throttle by wire rather than throttle by cable?
standard 320hp enough?
Originally posted by illiniboarder88 View Postwhat is better about throttle by wire rather than throttle by cable?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Guest
Originally posted by Quiksilver View PostHey guyz what's up?! I'm currently working on purchasing a new 20V and I'm curious if anyone has feedback on whether the standard 320hp engine is sufficient power or is upgrading to the 340hp a must. Your input is much appreciated.
Guest
Originally posted by chpthril View PostTBW, all day long. Less resistance at the lever means easier to drive, no cable to get tight and need replacing. Computer control means less "hunting" with speed control engaged.
Originally posted by illiniboarder88 View PostUnless there is more than one version of the 315, it's a fuel injected enginebut my dealer ordered an 07 22i last year as a budget boat and it had a Merc 315hp carbureted. tktige was with me when we pulled off the breather. I 'bout $h!t my self when I saw this
could not believe someone was still using a carb.
Just ordered a 20i with the 320 MEFI which I was told is a new option for 08. Could have saved $1200 by going with the carb. but that would not have been a good decision in this day and age. It is basically the same motor and I am covinced, especially in the 20i, it will provide plenty of power. I guess I will find out.
Originally posted by tklopfenstein View PostJust ordered a 20i with the 320 MEFI which I was told is a new option for 08. Could have saved $1200 by going with the carb. but that would not have been a good decision in this day and age. It is basically the same motor and I am convinced, especially in the 20i, it will provide plenty of power. I guess I will find out.
That $1200 will come back 3x in resale valueThe 2 biggest reasons people upgrade boats is size and power. They may be the same 5.7 block, but they are worlds apart after assembly
Originally posted by illiniboarder88 View PostI have the 5.7 315HP, and mine is fuel injected. In 2000, the carb version is 260 or 265 HP.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I'm not claiming that 315 is a lot out of that block, I'm just trying to make sure that people don't mistake the old 265 for the present 315. It's amazing what they can do with fuel injection. They take the standard IO engine (4.3 merc) which had 175 hp, and make it 225 with fuel injection. I'm surprised they only get a 25hp jump with the 350. Does anyone know if the claims that fuel injection is more fuel efficient are true?
