Just noticed I have a slight leak in one of my taps cylinders. Not leaking a lot but was wondering if anyone has chaged out the cylinder. How much was the replacement and what it took to change it out
Taps cylinder leaking
Not expensive from Bennett, and you can buy on ebay.
http://search.ebay.com/search/search...rim&category0=
I wouldn't worry about a slight leak. Mine leak a little if they haven't been used, then they seal up again.http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by tktige' View PostJust noticed I have a slight leak in one of my taps cylinders.
Originally posted by tktige' View PostIts leaking between the piston rod and cyinder cap, looks like seals are shot.
Thanks for the info on Bennetts I will call them to get a repair kit.
As for disassembly of the cylinder, is the cylinder cap just a screw on cap.
any info out there on reassembly of the cylinder?
Post some pics as a "How-to" so others can copy your hard workOther than that, Mrs. Lincoln, how was the play?
