Originally posted by Ruune
View Post
2004 Tige 22V
tessa
Originally posted by tessa View PostAccording to the Tige rep the vinyl is softer and seams have been redesigned and should not have problems of older designs as of a conversation today.
yours is definitely better then mineMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
tessa
tessa
Originally posted by hoppas View PostYeah, it's a lot of gas. Now that I think about it, I might have the 11 gph number wrong - this was a few months ago and it might have been 8 gph. It was a lot more than I thought it would be. The 24 gph is right though, at 5500 RPM with 4 guys in the boat, slalom mode, on a perfectly smooth lake. Slowing down to 35 mph dropped the consumption into the teens (I'm thinking 18 gph or so).
This spring when I go back out I can hook the flow sensor up again and double check. I've used the same sensors to check some other marine engines (stern drive merc's and 2 outboards) and it's usually pretty close to the factory installed gauges.
As for the vinyl, I don't get it. It seems like a design problem, and I've noticed the newer boats have the seams done differently so than mine so Tige has probably improved. I'm thinking of going to a local upholstery shop and seeing what they can do for reasonable $.
tessa
Originally posted by chpthril View PostThe only problem we ever had was with the VDO automotive style electronic gauge cluster. The Speedo would when it wanted to and this was usually when we where tubing or cruising, and go on strike when when boarding or skiingWhen you would turn the Nav lights at night, the cluster would glitch out and the warning lights would come on and the gauges would wig out.
Waited till we were ready to sell it before replacing the $600 cluster. 4Winns only used the VDO's for 2 yrs due to high failure rates and went back to all manual gauges.I think the automotive cluster VDo's went back to 04 as the first year. Their literature really pushed the benefit. I had no problems with mine with exception to two sending units,
Originally posted by tessa View PostI think the automotive cluster VDo's went back to 04 as the first year. Their literature really pushed the benefit. I had no problems with mine with exception to two sending units,
