Bent Prop - Ugh
    Bent Prop - Ugh
    Ended up bending my prop today while putting the boat in the lake today.
    The water was at an all time low and the boat launch ends up backing into some flat rock - apparently we werent the only ones to do so today.
    Anyways - I have an 03 22v - can anyone help me out on a replacement prop part number?
    Ive been reading and it seems like ACME are the ones to go to for props.
    Any advice?
    Thanks
    _Rob
    Call acme and tell them what boat you have. Probably a thread on here telling you which one to buy. Bought mine at propellersonline.com and got a good price. Props and rocks, bad combination. Check your strut too.
      That sucks.
      Year number 2 is coming to an end with our 22V and so far, knock on wood, we have not had any prop damage.
      We do have a spare just in case.
      Formertigeowners.com
        Look up the Acme 857. It is supposed to be good if you like to load your boat with weight.
        I had the right to remain silent, I just didn't have the ability. -Ron White
