I thought I would give a little update. I take back everything negative I have said about Lakota Watersports. After learning more information I found the source of most of the delays was actually Tige'. In spite of Tige's unresponsiveness to calls from me and the dealer the boat looks FANTASTIC. Actually better than it did before the accident. It should be done by this Friday if Tige actually delivers the last few parts.
Let me give you a taste of the latest trickery by Tige. The dealer called tige to order new cushions for the boat. After a delay, Tige called and said they need the old seats because they do not have the forms for the cushions. This caused yet another delay of several days while the cushions were mailed. I was told they needed the cushions because they "hand make" each seat for a custom fit. Of course the charge for just the seat bottoms was between 4 to 5 grand. I looked closely at the seats yesterday admiring the nice new vinyl only to find the cheap skates actually used the same backing with the same stained brown vinyl loop to pull the cushion up. The loop is brown and nasty looking which is BS for almost 5 grand. Once I get the boat I will make sure to post a nice big picture for you to admire their work.
I am still not sure if I will keep it based on the whole experience. Time will tell.
