05' tige 22v
    05' tige 22v
    this is actually my first post and me and my friend are trying to fix the impeller on his boat... except i cant find anything on the vortec engine? can someone help me out
    -Graig
    -Graig
    Welcome to the forum, Try this sticky thread under How To http://www.tigeowners.com/forum/showthread.php?t=609
    Depending on what engine you have, the pump may be located in a different spot and may disassemble differently than the tutorial, but the tips about removing and installing the impeller will be the same. Also take a good look at the housing for scoring and replace as needed.
    Also use the Search button at the top for more threads about Impellers. Alot of info here and a lot of knowledgeable people here.
      follow the water intake hoses in to the housing then take it off and switch them out.
