Commercial sewing makes the factory tow cover with the Tige logos on it. You can only order it from the dealer. It is very tight but you need to put some pipe cover (foam stuff for water pipes) over the window top to prevent chaffing. I have not had any problems with the gel getting chaffed, but I know Bug has had a few small spots on his MC with the same type of cover. I think it comes down the shape of the hull and how it contacts it. If you do get a spot where is chafes then some felt or flannel under that area would fix the problem.
http://www.commercialsewing.com/products.html
http://www.commercialsewing.com/vacuhold.html
