Starboard side on the transom (#3 in the pic above) is the one that they show the drinks in...
Activity Center - where does it drain?
Originally posted by Timmy! View PostStarboard side on the transom (#3 in the pic above) is the one that they show the drinks in...
However, I have seen the drinks in that compartment on brochures but looking underneath to see if there is insulation, there isn't any on my boat on that compartment. Since I don't use it for a ice chest, I don't care but it is funny to say the least.
This picture is from the port locker looking at the door 1 and 2 of the activity center. Notice that the foam insulation stops and then there is nothing.
So, there is two compartments. The first compartment is door 1 (uninsulated) and door 2 (insulated). The second compartment is door 3 (uninsulated).
Q1: Why would anyone put ice or anything cold in compartment 1 when only half of the compartment is insulated????
A1: Tige??????
Okay, I still love my boat no matter what. I can glue some insulation onto compartment 2 under door 3 if I want to have another ice chest......Attached Files
My guess is that the insulation is there for engine/exhaust heat and not to keep the "cooler" cold.Attached FilesLast edited by chpthril; 06-13-2007, 01:37 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostMy guess is that the insulation is there for engine/exhaust heat and not to keep the "cooler" cold.Does anyone know the R factor in fiberglass?
Just saw the picture with the circle you did. That "tube" is also insulated and has a soft material over the top of it.
Originally posted by da.bell View PostYou are probably right. But, I thought Tige is suggesting that one of the "bins" is also a cooler????? Looked on Tige's website and they only say insulated coolers with drains. That sounds like more than one cooler that drains to me.Does anyone know the R factor in fiberglass?
Just saw the picture with the circle you did. That "tube" is also insulated and has a soft material over the top of it.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
