Activity Center - where does it drain?
    Originally posted by dogbert View Post
    Mine has a 12V adapter in it, so I doubt it's intended for use as a cooler. It does have a drain, tho.
    only 1 out of the three is meant to be a cooler, the other two are just storage
      Well, there are two compartments. One compartment is handled by one door (3) while the other compartment is handled by two separate doors (1 and 2).
      Here is the problem that I found and would be interesting to find out if anyone else has this issue: Only area that is insulated is under door #2 while door #1 is not insulated. Seems to be a little difficult to keep anything cold in an "ice chest" if only one half of the "ice chest" is insulated.
        RZ's only have 2 compartments instead of 3 and I'm not sure if they are insulated or not. We'll find out how well it works this summer when it's 100 out!
          We have two compartments also. But there are two doors handling one compartment.
            Oh, we only have 2 doors with 2 compartments - you are so much cooler - no pun intended, or was it?
              LOL!!!!
                Our '07 22Ve is set up exactly like da.bell's with the storage on the left (has 2 doors) and the "cooler" on the right (has one door). I have not tried to use the far right one (the "cooler") to store drinks/ice in yet. As it is now we have our braided surf rope in the far right storage.
                Over Memorial Day weekend it was about 95 on the lake and when we pulled our boat out of the lake at the end of the day I opened the doors to see if there was any water in there from the ropes and I was very surprised to notice that the surf rope in the "cooler" was damp and cool. It seemed like it was pretty well insulated. I figured it would be hotter than heck but it was actually quite cool.. next time out I think I will throw some drinks/ice in there and try it out. Maybe it will actually work!
                If you ain't falling.. you ain't trying hard enough..
                  Have you checked to see which compartment has the insulation on it????
                    No I haven't and I am away from the boat right now or else I'd go check. I was wondering, after reading your post, if maybe they changed the insulation for the transom activity center for 2007?? Just a thought..
                      I am pretty sure that all of the coolers and a few other places all drain to the transom area. I have used my coolers several times and have never had the bildge turn on, on it's own. It must take a good quantity of water in the bildge before it will turn on. I usually drain mine by taking the plug out and raising the front of the trailer to a steep angle to let it all flow out. While there is discussion about coolers, I will say that the cooler under the seat rocks, it keeps ice upwards of two days, works really well. So does the complimentray cooler bag from tige' with the boat purchase.
                      I don't want to go to work, take me wake surfing instead!
                        "Insulation?"
                        I have no insulation on any one of the 3 doors. I have used the port to center compartment as a cooler and it worked, ok. Ice didn't last long and I didn't use anything to plug up the drain, so it worked fair. I now use only the one under the seat. I am surprized to hear that there is insulation on one of the doors. I have nothing like that.
                          Unless I misunderstood.. I think what da.bell and I were talking about is insulation around the starboard side "cooler". On the inside though not on the door. None of the doors have any insulation but I think that around the box might.
                          And you said you used the port to center compartment as a cooler once.. those aren't supposed to be used as coolers.. those are for storage. Only the starboard side one is a cooler from what I've heard and what the dealer told me. I've heard that the starboard one actually works pretty well as a cooler.
                            The insulation is the engine area and not on the door is correct.
                            The bin that you are talking about is not the one that is insulated on my boat.
                              In the '06 Brochure they refer to it as a "hydration center" and show a picture of it with ice and drinks.....I don't have my '07 brochure to see if they still call it that in there.
                                Refer to the starboard one as the hydration center or the whole thing?
