Originally posted by ragboy
View Post
24Ve Major Fuel Issue
Wake Havasu
See the following threads:
http://www.tigeowners.com/forum/show...ght=Fuel+Guage
http://www.tigeowners.com/forum/show...t=Fuel+Guage">
http://www.tigeowners.com/forum/sear...searchid=47355
W A Y BACK in 2004--
The thing is, the fuel gauge should work, mine works very well. Of course I don't trust it unless I am at idle in the water. My problem was the way the fuel filled in the tank, and how hard it was to figure out how to fill it to the top. Once I got that down, fuel gauge works better, and is more accurate than my last 2 boats.http://wake9.com/
anhaney
I have a diffrent tank set up than that in my 24V. I it is close to the same but a little diffrent. I have found I don't have any problems with SPLASH over as long as the nose is down and I don't over fill it. My fuel guage is real accurate. When it reads 1/4 tank you'd better get of the lake.
The first three years I owned my 22v I only filled it up at the dock, and I had to be very careful not to spill gas in the lake (big fine if caught). I still have the problem on the trailer, but not as bad. I love my Tige but I never saw the Malibu, Mastercraft or Correct Craft guys laying on their side with their ear to the gas filler because they were worried about spilling gas, plus everyone hated getting behind me at the pump because it took forever to fill up. If Tige wants to play with the big boys then they need to get it together and start paying attention to the details. Alot of companies have been successful building a hull and bolting in a motor, it's the details that make all the difference between the big players and the wannabes.-Tip
Well, my gauge decided to really work like a charm after this weekend. Not sure why it is reading correct now. I had it dialed in when I knew I has okay until the gauge started to drop off Full. Now it is reading 3/4 full from a weekend of boating (not used a lot). Just simply amazing I would say. I guess it took time to work itself out.
Feedback I've gotten on other boards is that most boat manufacturers are now getting the fuel tanks/sender units as a single item that they then install. It's actually the shipping of the unit that can cause the sender mechanism to jam.
Just run over a couple of tuber wakes and you're goodCursed by a fortune cookie: "Your principles mean more to you than any money or success."
anhaney
Originally posted by da.bell View PostI like that idea. Especially out here in CA where the lawsuits are plentiful.I do have to admit I enjoy sitting at a table in a restaurant eating my meal with out smelling cigarette smoke.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by Tip View PostThe first three years I owned my 22v I only filled it up at the dock, and I had to be very careful not to spill gas in the lake (big fine if caught). I still have the problem on the trailer, but not as bad. I love my Tige but I never saw the Malibu, Mastercraft or Correct Craft guys laying on their side with their ear to the gas filler because they were worried about spilling gas, plus everyone hated getting behind me at the pump because it took forever to fill up. If Tige wants to play with the big boys then they need to get it together and start paying attention to the details. Alot of companies have been successful building a hull and bolting in a motor, it's the details that make all the difference between the big players and the wannabes.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
My fuel guage is still working and I don't have an issue with gas filling either. Ruune nailed it. Don't put the pump on the maximum fill setting. Usually, one notch below the maximum causes no problems and, quite frankly, isn't all that much slower.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
