Originally posted by Jacksonville 22VE
View Post
Steering Cable
AN I DRIVE IS WAYYYYYYYYYYYYYYY EASIER THAN A V OR VE. AN I DRIVE TAKES AN HOUR THE V AND VE SERIERS IS MUCH HARDER AND I MEAN ALOT!!!!!!!!!!!!!!!!!!!! DID I MENTION THAT A V/VE IS ALOT HARDER. ZAD0030 COULD NOT BE MORE WRONG!!!!!!!!!!!!!!!(WITH ALL DUE RESPECT) VE/V CABLES ARE ALOT OF WORK!!!!!!!!!!!!!!!!!! BACK SEAT COMES OUT/ FLOOR /GAS TANK LOOSEN AND LIFT. IF IT HAS BALLAST EVEN MORE DIFFICULT TO ACCESS RUDDER!!!!!!!!!!!! AND THEN THERE IS THE WHOLE GETTING THE STEERING WHEEL CENTERD THING.Last edited by kko; 02-25-2007, 01:56 AM.
Originally posted by kko View PostAN i DRIVE IS WAY EASIER THAN A V OR VE. AN I DRIVE TAKES AN HOUR THE V AND VE SERIERS IS MUCH HARDER AND I MEAN ALOT!!!!!!!!!!!!!!!!!!!! DID I MENTION THAT A V/VE IS ALOT HARDER.
As for centering the steering wheel we planned ahead and turned the wheel all the way to the left to that the tiller arm was at close to us as possible. then made sure that the new cable went in in the contracted position so that when we connected it to the steering wheel it was already aligned.Last edited by zad0030; 02-25-2007, 02:29 AM.Common Sense is not so Common
Originally posted by Domsz06 View Postha ha ha, then no one will believe you.
"O look at that 15 year old, hes pretty funny but I would never let him tell me how to fix something on MY boat!"Common Sense is not so Common
Originally posted by kko View PostAN I DRIVE IS WAYYYYYYYYYYYYYYY EASIER THAN A V OR VE. AN I DRIVE TAKES AN HOUR THE V AND VE SERIERS IS MUCH HARDER AND I MEAN ALOT!!!!!!!!!!!!!!!!!!!! DID I MENTION THAT A V/VE IS ALOT HARDER. ZAD0030 COULD NOT BE MORE WRONG!!!!!!!!!!!!!!!(WITH ALL DUE RESPECT) VE/V CABLES ARE ALOT OF WORK!!!!!!!!!!!!!!!!!! BACK SEAT COMES OUT/ FLOOR /GAS TANK LOOSEN AND LIFT. IF IT HAS BALLAST EVEN MORE DIFFICULT TO ACCESS RUDDER!!!!!!!!!!!! AND THEN THERE IS THE WHOLE GETTING THE STEERING WHEEL CENTERD THING.I recall you or Dom saying it feels like you were in a car wreck after doing the cable in my 22v? It was like butter when you got it dialed in for me though, thanks again.
Zad,
If you become a boat designer/engineer, let me know when your hiring, I could help you out!! or buy a boat from you as well
I always wanted to get into desigin, but had to do something else first.Originally posted by G-MONEYIt hurts me to say it but go OU but only for this weekend!!!!
