Copper Line Leak - Help Please!
    I was checking to make sure my boat was lake worthy and had the fake-a-lake running when I noticed a leak from some copper line that looks to be running to the bottom of the water separator. I'm assuming it had a touch of water in it and froze. Is this copper line something i can just remove, purchase new line from the hardware store, bend as it was, and replace? See attached picture. Thanks in advance!!
    Looks like the copper line is the fuel pump cooler. I doubt i can find this locally. https://marineenginedepot.com/cooler...sure-fuel-pump
      Thats what you want. If can jump the water line from the coil the g force fuel filter you should be able to run until the coil shows up
