2001 21v fox edition 350hp. Hi. I am totally new to the group obviously and new to forums as well. Please be gentle. I searched the site and found a bunch one ballast for the boat for surfing. What I am looking for is the best placement and % front, back and sides to add weight. I understand the need to change the rear weight from left to right to adjust for goofy or regular. I hope someone can help. Thanks in advance.
2001 21v fox surfing ballast help
Welcome. First off!!!!
I did a lot of research with our stile hull. You can read about it here "quest for the wave" (not sure how to link) My option is you can get a really nice from our boats that will compare to any boat here. There are some mods I think are necessary. I currently run 1150 each locker 1000 up front. I use a suck gate. 2571 prop. 11.2 mph.
Although 750 each locker V bag up front +100 in lead doesn't suck. Acme1433 10.8 I am at 600 elevation. blue v drive. actually I recommend the 750 setup if you roll with a big crew.Last edited by gumby; 07-18-2019, 01:05 AM.
The 1050 setup mods that are necessary.
Engine air intake. When you are loaded down it is so close to the water One person standing on the back gets scary. To me.
My natacurl is also modified to fit the hull. and a few other mods to make the surface bigger
You Got to drive just can't jump off the gas. the wave will come in the vent. You can NEVER turn around on the surfer side.Wave will come over the front.
Lead you will need some 400 lbs
Chrip can help you sacks and pumps, props and such if you plan on pluming it all in.
1050 mods? Usually just a bunch of kids less than 150# each that I can adjust position. I plan on using static weight instead of fillable sacs. However, I can love the weight around in 50# increments to adjust to front, front side, rear bench, and rear lockers. Just trying to find out what the best ratio is. I apologize if I am not asking for the correct question or know the abbreviations of some answers. Still learning.
All good. We were all beginners at one time.
You will need sacks what type is up to you. You can't drive around with 3000 pounds of Lead in the boat all the time. If that is what you mean by static. I mean I guess you could just keep good insurance on the boat. and might make it hard to get on the trailer. O the poor trailer. LOL
Makes sense on not just cruising around with that much weight. Boat sits on a lift but yes you are right about having all that weight in the boat all the time. Seems I am looking for a realistic balance of weight, suck gate, and prop to have to adjust “lightly” to be able to surf or just ride around when needed. Am I unrealistic?
Just to give you an idea this pic is only 400 each corner me 190 ish and the dog. Front full.
