In my search for my next Tige, I found that the 2005 24V that I am looking at has a 3 blade prop while my 2000 2300V has a 4 blade prop. Why the change over the years and is one better than the other for boarding and surfing?
Props-3 blade or 4 blade
V-Drive usually have 4-blade
Direct Drive, usually a 3
I had written up the math on how to choose pitch and size in another thread, or how to base a decision rather. Might want to search for it.
***edit***
Found it
http://www.tigeowners.com/forum/show...ight=prop+slipLast edited by spharis; 11-10-2006, 07:54 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
What is the gear ratio of the V-drives? Our 2000 21V could have come with a 1:1 or 1:1.46 ratio. The V-drive gear ratio is the biggest factor is determing 3 or 4 blades. Ours has the 1:1.46. I ordered an Acme 537 13.5x16 4 blade for it. If it was the 1:1 Acme reccomended another prop that was a 3 blade. Maybe the 2005 24V has a 1:1 V-drive and the 2000 2300V has a 1:1.46.
Originally posted by TigeDuner View PostDo you think the same will hold true for a boat as heavy as the 24V ???????????????Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
