I have a 2005 Tige Switch V with a 340 Indmar. I noticed hot temps in the 190-200 range so I switched out the thermostat and impeller. After 5 minutes in the boat with light load the temp was right back to 195 degrees. I lifted the cover and the starboard riser was hot to touch while the other side was just warm. Can I get some diagnosis help and advise? Thanks.
