oil loss v-drive
    oil loss v-drive
    I noticed after the ride, the low level of oil in WALTER GEAR DRIVE (RV-26D) does not drip into the hold, I think it goes into the cooling water. Is it so? How can I check? Thank you!
    There is a water cooler, so yes, v-drive oil can end up in the raw water cooling. Pull some hoses on the outlet side of the v-drive and feel inside them.
      I think to remove the oil hoses and let the air into the tube.
      I'll remove the top cover and there may be air bubbles from the tube oil
        when removing the tubes of oil, what to change?
        I want to be ready.
          found a malfunction, flange collapsed
