2000 2100V that we have owned since 2010.
I have noticed a 1" to 1.5" list to starboard with boat unloaded the past several years. (list may be slowly increasing) I have pics of it floating level in 2010 and 2012.
No new equipment has been added.
I am wondering if it has retained water underneath the floor on the starboard side.
If I remove the house battery from the rear transom compartment and reach thru oval hole in floor of battery compartment I cannot find a drain/passage from the locker floor to this rear bilge compartment under the battery. I did find a large oval hole between rudder area and area under starboard battery compartment.
I also noted evidence of a black watery liquid dripping from rub rail on starboard side on on last long road trip. (stained hull and trailer) Did not have this on port side.
Does anyone know if/where there are drainage passages from these starboard under floor areas?
Does anyone know what is under the floor, is there floatation foam under there that could have become saturated.
Thank you for your input.
