Please help out a new tige owner. I have searched the forum and found most of my information but have a couple questions.
Bought an 08 Z1 with 44 hours on it. I am going through and checking everything before winter and having it winterized.
1. Both of the caps/dipstick on my transmission and v drive seem to be painted same color as the transmission and v drive(chipping off easily). In other pictures of z1 they are red. Not a huge deal I just want to know if it is something the previous owner did or if they had something done to the transmission and v drive.
2. I am flushing out my v drive fluid as it is just slightly milky. I extracted about a quart, is their a drain plug on the v drive I can drain the rest? Hurth ZF IV. When people refer to flushing out with Diesel I assume they mean fuel? correct?
3. When I opened the cap/dipstick for v drive and tranny there was what sounded like quite a bit a pressure releasing. Is this normal?
4. If there is in fact water getting into my v drive how tough is this to fix? pulling whole v drive and tranny out?
5. I bought 30W oil from west marine to put in the v drive. Is this sufficient? I believe it is just heavy duty 30w 4 cycle engine oil.
6. I had a small leak from my PSS first time out. I took some 800 grit sandpaper and slid it between the metal ring and the charcoal hoping that would fix it for the last couple times of summer use. I noticed that my shaft seal does not have a water hose connected to it as in the pictures from pss. Is this just a factory seal that came with it? Or should I be ordering a new one with the water hose connected to the charcoal.
Thank you in advance for the answers. I am new to owning a boat but loving every minute of it so far and really enjoy working on it.
