Replace old gauges
    Replace old gauges
    I really want to replace my ugly gauges. I have a 2003 tige 22v riders edition. Anyone have any ideas???
    Welcome to the site and the Tigé family. Posture pic of your 22V when you can.
    I'm not familiar with your year/model, but someone will. Maybe post a picture of the dash too.
    Here are a few types that might work.
    http://www.boatersland.com/faria.html
    http://www.boatersland.com/telinst.html
      Thanks Mike, I did some more research and found my boat has the Faria Commander series. The tach has a digital display for water & air temp, can't find another plug & play that has air/water temp so I'll probably just live with current gauges. Cleaned them up using some wet sandpaper and headlight restorer. Worked pretty good! Probably just gonna live with them???
        The needles started falling off of one of my gages, I contacted Faria through their web sight and had them repair/replace it. After coming back it looks so much better than my other gages I'm thinking of sending the other 2 gages just to have new glass put on them. I think it's about $25 to get the new glass. Go to the repair section on their sight, also the guarentee the work.
          ^That's a great idea ^
            Thanks for that info because it looks like I'm going to need it! Cause my frickn oil pressure gauge isn't working now? I tested everything and it looks like it's the gauge, so I'm sending to Faria. Thanks again!
            Why is it whenever I start working on some electrical problem, it seems to snowball into something much bigger than I thought it would be? Now my taps gauge isn't working properly and the trim tab won't move when I push the trim button (either direction)??? Arrrrgh! Gauge has only 3 posts, purple wire to "I" post, Black to middle for ground, Yellow to "s". So I have an Orange wire left over? Anyone know if this goes to "S" with the yellow???
