I wonder if it makes a difference what wax you use or what the water is like you ride in. I find that it gets harder and harder to get the water scum off of the boat after time. With a fresh coat of wax, it comes right off with just a simple wipedown.
I wax the whole boat, except the underside. I usually do it twice per year if I can.
I have found that waxing the whole boat and then doing clean-up with a mild solution of white vinegar and water works great to get the spots off... Wax on!!!
