I have a 2006 22Ve with around 40 hours on it. Recently while we are pulling someone, the boat simply hesitates, then goes again. This is not when we are taking off, this is when we have been going for a few minutes at least. Any suggestions? Previously our V drive was 1/2 a quart low on fluid.
Problem with 2006 22Ve Riders Edition
is it over heating?
if you have a 22Ve with the tranny cooler, it might be getting clogged if you do not have a water strainer. (i'm assuming since you are in austin, you're either on lake austin or travis? there is lots of trash getting sucked up in our 22Ve from lake austin, we're getting a strainer added this week.)
When it over heats it will try and die, sometimes it will cut off, sometimes it will remain running if you put it in nuetral quick enough.
Re: Problem with 2006 22Ve Riders Edition
Originally posted by jdheltne
I have a 2006 22Ve with around 40 hours on it. Recently while we are pulling someone, the boat simply hesitates, then goes again. This is not when we are taking off, this is when we have been going for a few minutes at least. Any suggestions? Previously our V drive was 1/2 a quart low on fluid.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
