My taps is stuck at 8. When i push the up or down button, I can hear the relay clicking underneath the dash but no noise from motor. The motor has plenty of fluid but is very hot to the touch. So I unplugged the motor and just boated for the evening stuck on 8. So, it seems like power is getting there, but motor is not moving. Is the motor shot, relay messed up, any ideas?
2012 Tige TAPS not working
Seems like the pump motor is shot since it's very hot. Ours doesn't get hot. The motor & actuators are made for Tige by Bennett Marine, bennetttrimtabs.com, FL - 954 427-1400, hydraulic power unit - V351HPU1, Dexron III. The standard V351HPU1 has 2 ports to control 2 trim tabs, so plugging one side will work with the single trim tab on our boats. Give Bennett Marine a call, they were very helpful.
