SO i took the boat out yesterday and it should off! everything shut down as if the batteries were completely dead. SO i shut my battery switch off for about 2 minutes and it fired right back up. Then it did it again when i was running the ballast pump and stereo that has one amp to it. so i did the something and it fired up. Then five minuted later i was at a cursing speed and everything shut down once again and then i disconnected the amp and stereo completely then dove the boat fast for about 8 minutes and the boat ran fine all day. Whats going on?? I have 2 starting Batteries right now. Is it the batteries or alternator?? Help please..
Boat shut down yesterday But Started
not sure if you battery charger can test alternator output. but I would start there. that would be free to find amp output. But I would suspect as you do. its one of those two items. but you could pull the batteries and have them tested at any local autoparts store as well for free.
but going with batteries if I was betting based on what u have already done.2011 Tigé RZ4
www.re-viveupholstery.com
Originally posted by cclarke89 View PostSO i took the boat out yesterday and it should off! everything shut down as if the batteries were completely dead. ... I have 2 starting Batteries right now. Is it the batteries or alternator?? ...
Also, are both batteries hooked up for starting? Usually the second is connected to accessories so the accessories won't drain the starting battery. A 1-2-ALL switch allows switching to the backup battery if the starting battery has issues.
Ill make a long story short. took the boat to my mechanic he replaced my alternator, fixed a broken bracket and installed a ACR and that didn't fixed the problem. So was talking to my buddy thats a John Deer Mechanic and explained to him what was happening, instantly he goes "Thats a circuit breaker dude". Did some reserch picked up a 50amp circuit breaker and she ran like a champ all day blaring the new system.
