Here's an odd one.
We have a severely bent fin.. that we aren't clear on how it happened.
It's the rear most fin of the 3.
It seems very odd that the last in line was the only one damaged.
It could have been when we were anchored off in some shallow water and only that fin made contact with something.
The bottom where we often tie off is very very silty and don't often get close enough to shore to worry about contact.
Anyhow.... I took a picture tonight when we pulled the boat for other reasons.. like to clean the hull and get a fresh coat of wax on it.
Now I need to order a replacement and figure out how to remove it.
The HID is: TIX06401K203
Can you tell by the HID if it can be replaced from below or if I have to pull the tank?
When I replaced the steering cable last year I learned that the tank is really jammed in.
I removed all the retaining screws and wasn't able to lift it out.
Probably just couldn't find the magic angle to get it out.
This seems to be the year for dumb stuff for us.
Thanks all in advance for all your input.
So it's not even close to even yet.. But I'm a tige man for life.. that's for sure.. Thanks for the update man!
