I bought a Tsunami inline pump to drain my 750 sac and I want to wire it to the drain pump on the factory ballast tank. The problem is that i cannot reach, let alone see, the drain pump. That said, I can see two small wires running down behind the batteries - one brown and the other black. I assume these are to that pump - can anyone verify that? If so, I could splice into them and be finished this project!
The Tsunami pump wires are far too short to reach. Does anyone know the gauge of the factory wires...16? 18? I plan to buy a little automotive wiring to make up the difference.
