Originally posted by TigeTrojan
View Post
6.0L Overheating
Sounds like that temperature Mod is working well. Maybe I need to try it?
Marine Power told me the boat should operate around 200 degrees with the new thermostat.
When I look at pics I took of the boat before the problems, I can see the temp guage at a steady 175 degrees.
Anyone ready to buy a Tige?
Originally posted by Pwood View PostOwners - Be sure you are using the correct impeller. Dealership "thought" we were .. Turns out we were not.
Now that the correct impeller is in - Water is being pushed through the heat exchanger very well - 24 gallons per minute.
